- Joined
- 13 Feb 2004
- Messages
- 25
- Reaction score
- 0
- Country
Hope someone out there can help. I have a woucster heatslave 9.24 combi boiler, in the house I have just moved into. Today, although the central heating works fine, when the central heating is not running, (thermostat switched off CH), when I try for hot water the boiler refuses to fire up. I can hear water running through the system, and when the hot water tap is on, a click is heard from the boiler, but no boiler fires up. The same happens when the system is switched to hot water only. When the central heating is running(thermostat allowing the system to run), the water heats up OK!!! I did notice however that the pressure was <0.5bar. I tried again later on, and it worked OK, and I noticed the pressure was now 1 bar. There does not appear to be any leaks anywhere, and no water drips from the boiler. The radiators all work perfectly except one, which only gets lukewarm, no matter how much I bleed it, even though the pipe going to it, gets schorching hot. Any suggestions as to what may be happening would be appreciated.
rgrds
Chris
rgrds
Chris
