No hot water, CH fine.
15 Dec 2011
Yorkshire
Hi there.
Yesterday, I stopped getting hot water. The heating is fine, and when a hot tap is turned on the boiler responds (i.e. flame and noise), but no hot water comes through.
From reading other people's posts on here I suspect it is the 3 way valve...
If so, how do I check to see if it is this? Can I fix it myself?
I am an utter newby so simple please!
Thank you so much.
The boiler is a Thema Condens F 30 E.
I wouldn't advise doing this yourself if you're a "newbie"
But yes, it sounds like it is the three port motovised valve.
Do the rads heat up when you turn on a tap for a while?
Likely to be a slightly more involved repair as it sounds as if the motor has failed and probably because water has leaked into it.
