No Hot water from my ARISTON A/23 MFFI
14 Jan 2009
Merseyside
:( Hi could anyone help please, the heating on my boiler is working fine but when i turn on the tap for hot water, it is only just tepid. also when the heating is off the boiler does not fire up when hot tap turned on! Is this due to the flow switch or the diverter valve and if it is the diverter valve does it need to be replaced or can it be repaired? Thanks in advance for any help you may give.
I would suspect the diaphragm in the top of the diverter valve
