No hot water on combi
11 Jul 2005
Cheshire
Hi All
Have a worcester bosch 24cdi (on gas). central heating working ok but not getting any hot water when hot tap is turned on.
By replacing the part!
However before replacing anything I would recommend the diagnosis is confirmed.
Tony
Please be aware that there is fault-finding process that leads to reasonable confidence of determining which part has failed. Fault-finding is rarely easy for a novice, even with the kind of advice you can find on this forum.
Having said that, if an assistant opens a distant hot tap while you press your ear to the boiler, can you hear a "click"? You should hear one, because this is the noise that the flow switch makes. If you don't hear the noise then it's quite likely that the flow switch is faulty.
(Where's Joe when we really need him?)
I would always advise a proper electrical check rather than listening for noises!
Tony
I would always advise a proper reading of the preceding posting(s).
