No hot water pressure
26 Jan 2006
Leeds
I have a Vokera Compact 24 boiler. There is barely any hot water pressure. The taps need to be fully open, there is a fast spurt of water and then it slows to a mere trickle, that takes several minutes to get warm.
The pressure meter on the boiler reads 1 bar.
Any ideas on how to fix it? Or how much it will cost?
Thanks.
Is this something relativiely easy to sort out, or would I be best getting someone out to take a look at it?
Just isolate electrical supply to boiler turn off cold supply open hot tap undo nut remove restrictor and throw it away, repeat in reverse.
