NO HOT WATER UNLESS CENTRAL HEATING ON? HELP!!
17 Mar 2008
Lancashire
can any one help? having probs with my boiler. central heating works fine but can`t get dhw without the heating being on as well. its a heatline combi boiler. seems like the dhw pump not kicking in when demand is made? :(
if the pump isnt running then that seems to be problem.. also check to see if diverter valve is switching over.. and while your at it check the dhw thermistor.
Hi Thanks for that! Is it a job for a proffessional as I don't have a clue about boilers? and how much would it cost do you think? :?
it would be good to get a engineer to have a look just make sure when you call to ask about call out charges. hope you get it sorted
They will say that the diverter valve has failed!
Tony
