my flat is all electric with a hot water tank,however i am all of a sudden getting no hot water at all! i have checked the fuses etc and all seems to be ok,please help!
I assume an immersion is used to heat the water?? if so check the reset button on it hasn't popped out. If so reset......might be broken too so it might need replacing.....check also if your timer/programer is working....
yes its heated by an immersion but its only about 6 months old.i have pressed the reset button to see if it does the trick.will let you know,many thanks.
Wiggikins is right.....did you have a power cut? anything electrical trip or blow? These things shouldn't be related but it happens. If it happens again get a pro sparky to check it out....
still having problems with the immersion,the reset button keeps popping out! is this just a case of getting a new immersion or is there a possible electrical fault causing it to do so? the immersion is only about 9 months old.
