hi again,got a problem and hope someone has a fix.
the 2 motorized valves where changed last year,everything working fine until yesterday,no hot water.
with hw and ch off,the little levers on the valves have pressure and when pushed fully over they return to the normal setting.
when i turn on the hw only nothing happens,the levers stay the same and the boiler wont even kick in.
when i turn on the ch,the radiators get hot,no hot water,and the lever on the ch valve goes loose,ie no tensionand when i turn off the ch i can hear the ch valve whirring and it goes back to having pressure on the lever,does it every time.
surlye it cant be sticking allready as this will be the 3rd one that has been fitted in as many years.
thanks
thanks
