- Joined
- 30 Nov 2007
- Messages
- 3
- Reaction score
- 0
- Country
Hi all
I switched on the kitchen light this evening and there was a bit of a bang and all the lights went off.
I have checked all the fuses in the CU and they were fine. Checked all the lights and found a loose connection which is now fixed but still not working.
I am therefore going to get an electrician in, but what is the possibility that the CU is the problem and will need replacing?
the reason I ask is that whoever designed the house had the bright idea of locating the CU in the Kitchen behind the units, and there is just enough room to squeeze in one of the cupboards and change the fuses.
is it worth me dismantling the kitchen before he visits so he will have better access to the CU?
thanks in advance
thanks in advance
