Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I ask because if the same clowns that built a concrete block (not a thing in the 30s) wall on timber joists did the extension which involved knocking the downstairs back wall out, I'd have serious misgivings about the quality of support offered to the upstairs wall where the extension was added. Have you seen any indications of problems there?
Loads of partition block walls (of the period) were built like that, usually off a sole plate fixed to the floor joists. Same in my house. I bet that door casing is only 100mm wide, meaning the partition blocks are your typical 3" fellas.
Lots of houses have wooden lintels, even some modern ones. Mitigating the inevitable shrinkage is the important bit.
As I said, thousands upon thousands of homes up and down the UK have first floor 3" block partition walling. Issues usually arise when folk do internal alterations.
Yeah OK, a lintel was pretty normal. Had the same in our old bungalow, was only holding up a few courses over a 3-foot span. But sticking a wall in the middle of floor joists seems crazy. You're putting something heavy that can't flex on top of something that definitely will bend under load.
