yes rjm2k thats exactly it, timered extractor is what i need to fit
That's handythats good i have bought that very isolator.
If it's a two pole pull cord with N terminal, yes.where my neutral is not connected in my pull switch (just looping through) should i cut and bare it to join all 3 N into the switch N terminal
No problem, we like to help!thanks by the way, Dom
What don't you understand?sorry still dont understand the connections at the pull switch end
yeswell Ive got everything up until the pull switch connected just not sure what to do there. I have a common, live and earth terminal being used and a redundant N terminal.
Do I put my black sleeved brown to the live
yesbrown to common
blue sleeved grey but yesand grey sleeved blue to neutral?
Terminate at switch, isolator and run to fan and connect in to small terminal block. It's will help with testing procedures, so still run it to the fan.as the fan is double insulated can i still terminate the earths in the isolator and switch?
Yes, make sure every thing has been safely isolatedLastly am I ok to cut and connect this neutral loop into the redundant N terminal in the pull switch?
