I have recently taken down a partition wall that was in my utility room, as part of some work that has been carried out in the area. In addition to some 13A outlets, the main power supply switch and the timer for the central heating both resided on the wall (it is adjacent to the wall where the boiler is located).
A new wall was put up in the same place, the following day and all of the electrics re-instated exactly as they were – or so I thought…
At the beginning of this week, I reconnected the power supply and whilst all the 13A sockets worked fine; no power was reaching the boiler (suggesting that I have either wired up the central heating power supply switch, or the timer incorrectly).
I took photographs of both boxes before they were disconnected – and I was sure I had put back all of the wires in the same place – but it would appear not…
Power is getting to the central heating power supply switch (the neon light glows when it is switched on) – and indeed to the timer switch next to it (the clock on it lights up and the red lights showing heat/water on, work as expected).
However, there appears to be no power getting from the timer switch to the boiler (it’s green power light isn’t glowing).
I called out a British Gas engineer yesterday, in case something just needed resetting or had fused on the boiler.
He went upstairs and manually moved one of the valve switches in the airing cupboard in the hope it might trigger some activity. Instead, it blew the 5A fuse in the central heating power supply switch.
At that point he left the house and told me I needed an electrician !
I am trying to get hold of a suitable electrician – but they aren’t that easy to find.
I realise that this problem is probably too complex to enable resolution via a forum – but I thought it worth raising in case anyone had any ideas of what the issue might be (I suspect I’ve just made a small mistake somewhere).
Details of the central heating power supply switch/timer/boiler are as follows:
Central Heating Power Supply switch
5 cables coming in: 2 for the ring main; a link to the room stat; a link to the timer; and a link to the airing cupboard (where the pump, motorised valves etc are located).
There is also a single core yellow which I think links the earth in the switch with the earth in the timer.
The switch is wired up as follows:
N load - Blue (room stat) and blue (timer)
N feed - Blue ring main x 2
L load - Red (room stat) and brown (timer)
L feed - Brown ring main x 2
Earth - Earth ring main x 2, earth (room stat), single earth wire (timer ?)
Connection block linking red (airing cupboard) with black (timer)
Connection block linking blue (airing cupboard) with yellow/green (timer)
Connection block linking yellow (airing cupboard) with black (timer)
Timer – Honeywell ST6400C
Has a cable coming in from the central heating power supply switch and a cable going out to the boiler - plus a single yellow wire which goes to the earth terminal.
There are 7 terminals where wires are connected – plus a connection block.
1. Earth - Single yellow wire (CH power supply switch ?)
2. Neutral - Brown (CH power supply switch)
3. Live - Blue (CH power supply switch) and blue (boiler)
4. HW Off - Nothing
5. CH Off - Nothing
6. HW On - Black (CH power supply switch) and brown (boiler)
7. CH On - Black (CH power supply switch)
Connection block linking yellow/green (CH power supply switch) and yellow/green (boiler)
Boiler – Baxi 100 HE
I believe that this is exactly how it was all wired up before I took the boxes off the wall (I took photos and made notes).
The only mistake I felt I might have made was with the black wires in the CH power supply switch – but I changed them round and it made no difference.
I’m a little puzzled as to why the Live and neutral in the timer are wired the way they are – but that is how it was (and I have photographic evidence to prove it !).
All thoughts/suggestions/comments very welcome !!
4. HW Off - Nothing
5. CH Off - Nothing
