I thought this photo might be useful - it shows the relative position of the power supply, timer and boiler, so should help you orientate yourself:
View media item 66769
2 cables go from the power supply up to the wiring box (which is located in the airing cupboard above the utility room).
One of these connects to the power supply directly, whilst the other is the link to the timer...
The power supply then connects to the timer, via a single white sheathed cable containing brown, blue, black x 2 and Y/G - plus a single yellow.
The timer connects to the boiler via a white cable which contains the same 5 wires as above - but the 2 blacks are unused...
