No Power Light on WB Greenstar Boiler
22 Nov 2009
Ayrshire
Hi all,
I've recently had a WB Greenstar Junior 28i fitted, which seems to be working fine. I noticed today however that the blue power light is not lit on the front. When the boiler is powered on from the mains, the light comes on but then goes off, when I do a reset all the lights come on and then go off.
Going by the manual, the blue light should be on at all times when the boiler is receiving power, it also performs a secondary function of diagnostic light by blinking codes. Is there something I'm missing here as I'm sure it should be on.
Any advice appreciated.
Don't panic! It is an option on these boilers to be able to turn off the blue power light, it seems like your installer has set this option... I can't remember how to turn it back on, I'm sure that one of the others will know and tell you... All other functions of the blue light will operate as normal
Thanks for the reply. I have checked through the users manual and also the installer manual as well. There is no mention of any options for this (possibly a secret installer trick). I remember the blue light was on when it was installed, but couldn't say for sure it was on after the installer left. I would like it turned back on as it a handy check that all is well, plus now it's starting annoy me in that irrational way that stupid things do.
Anyone?
Regards,
I too have the same problem on my Greenstar 28i junior. Blue light was on, now after a service it's off and the boiler still operates as normal. Can this light be turned on or off? The light will come on briefly as the boiler is powered off/on at the fused spur and flashes during service mode so I know the light is working. Any ideas?
