Noise coming from my Combi Boiler.
23 Nov 2003
I have an Ideal Response 80 combi boiler. All the upstairs radiators have thermostatic valves, all the downstairs ones have normal valves. I don't have any water tanks.
When the central heating system turns on from cold, after approximately 25 - 30 minutes a noise starts coming from the boiler for about 30 seconds to a minute. It's quite loud and sounds like a humming noise or maybe a vibration or maybe something spinning that is off balance. The noise starts off low pitched and slowly increases in pitch until it stops. Once it's stopped, it doesn't come back again until the system has been turned off and cools down. It is as regular as clockwork though. The CH comes on twice a day and within 25 - 30 minutes of it coming on the noise comes and then goes again.
The noise reverberates around the house nicely and generally wakes me up - it's better than an alarm clock. I'm not all that concerned cos the boiler is working well other than the noise but I am getting bored with the early morning wake up call and I'm worried it's annoying my neighbour.
Any ideas? I do have British Gas central heating care. Is it worth calling them out. Will they be able to fix it?
Thanks for any advice.
Dave.
Have you tried turning off the boiler just after it starts making its noise?
You could try some boiler scilencing chemical in the system and see if that improves things.
