A new boiler system [Boiler,Valves, DHW Tank, Grundfos Motor, Cold Water Feed tank, Feeder & expansion Cistern, Room Thermostat all replaced with new] installed and commissioned 3 days ago.
Regular Open Vented boiler with one valve previously is now replaced with
open vented boiler with S plan.
The Old Potterton 80F boiler with Grundfos motor attached to HR above the boiler in our garage. [Now the Grundfos is near the DHW tank in the airing-cupboard but the new boiler is kept in the garage as before].
The old system had one valve on HF in the kitchen [Photo No:5 & 6 ]. This was removed and both ends of the HF capped [Photo No: 7 ]
A new by-pass was created near the DHW tank in upstairs under-floor[Photo: 12 & 13 ]
http://www.flickr.com//photos/31216233@N03/sets/72157632201462143/show/with/8256362419/
All the radiators were bleed of air [throughly].
The plumber & Gas Safe Installer could not run the Grundfos on 3 as it seems to create a gargling noise & as I understood from their discussing that it may be pulling air?? So he'd set it at 1.
There is no over flow from the F & E Cistern.
Though Grundfos is set at 1, a low rumbling nice from the motor [like an old Refrigerator running noise] is very troublesome as our four bed rooms are by the airing cupboard.
The Rads were allowed to run with cleaner for two days and then thoroughly were flushed.
The Plumber and Gas Installer will be back tomorrow Monday.
I am to ask them if the noise could be stopped.
However If I understand about this better as what is going on, it would help me a lot when discussing with them - hence my question in here.
1. How could I get this noise from the Grundfos stopped?
2.Does it matter that the New Grundfos could not run on 3 because of it ??pulling air!!?
Can you help me?
Regards
Can you help me?
Regards
