I got some of googling sounds when my mothers trap got filled up. Also same sound when the condensate drain froze, also plumes of water vapour from flue.
As already stated there are other causes of noise, old TRV's would hammer if fitted wrong way around, but only been fitted two years so should have by directional valves fitted.
Again I know mothers boiler has two by-pass valves one exterior and one inside the boiler, I will guess it should not have two, so they could react with each other. There was a whole list of what I consider as errors when fitted, this is what happens when you use a large firm who flood the job with labour and are in and out in two or three days, among the tradesmen there are also labours and apprentices who make errors, like a power shower on a combi boiler.
Being fair those faults I found were corrected, but some faults hardly worth calling them back for, like every lock shield valve wide open.
I blamed them for lack of control, however it turned out to be more down to house design and the way the morning sun shines through the bay window. From programmers set to 10 programs instead of 16 to the pushing of thermostats and eTRV's which are completely unsuitable we as electricians tend not to rate plumbers, but to be fair the same can be said about electricians where we miss judge how often a RCD will trip etc.
Be it plumbing or electrics it is done to a price, may be all RCBO or EvoHome is the best option, but both trades try to reduce costs to the consumer and some times we get caught out.
If you had heard the hammering when my parents AGA boiled the water in the side boiler you would have thought the house was going to explode, but all we had to do was run off some water, this was when boilers actually boiled water, today may be called boilers but we would say there is something wrong if they do.
Anyway one assumes the poster has some common sense and has tried closing lock shield valves on each radiator and would have found the obvious, he would have tried lowing the water temperature, so looking at less obvious causes, I nearly stripped down whole boiler before I found how to remove and empty the trap, best of it was it was so easy once one knows how. But I am loathed to point the house holder to stripping down a boiler to find a fault, everyone to their own and I feel better to get some one how knows what they are doing, and of course watch carefully so you can do it next time.
I think what I did was wrong, I stripped down far too much in my quest to find the problem, OK did not touch any gas valve, but did strip down too much, so learning from my own errors I think my comment that they should get a service is correct.
