Hi, had a new sealed/unvented hot water tank installed. Hot water was back flowing up cold inlet and out pressure valve.
Plumber rechecked and adjusted position of expansion unit in the multi non return/pressure regulator valve and changed pressure - no issues there. However they have however then put a non return valve in the cold inlet pipe between the expansion vessel and hot tank. Doesn’t this stop the expansion vessel working?
Now when boiler comes on, water comes out the high temp and pressure valve on hot tank. Isn’t this becoming a bit dangerous, am I right to get them back asap?
On a side note, is it acceptable to have a slow leak on central heating plumbing. Water droplet hanging of joint, but not actively pouring out. Again needs fixing?
