Hello,
I've used this forum many times and much appreciate all the advice and help. I wanted to ask if anyone has any advice about the correct preperation for laying rubber tiles onto a 12mm ply subfloor. I've screwed the floor down over existing floorboards and distanced the screws approx 30cm apart on the ply. The only problem is that I'm not sure whether I should use filler on the seams and holes before putting down the tiles. The tiles are very flexible and I'm a bit worried that they might pick up the minor imperfections in the subfloor. The other problem is that I may have run the ply too near to the walls - how much breathing/expansion space do they need? Does anyone know how todeal with these 'problems'?
Thanks in advance.
Gustav
Thanks in advance.
Gustav
