Not enough catalyst
9 Aug 2015
Hi all. I did my fiberglass roof myself but had a small leak so I run the sander over it a bit and put down another topcoat but instead of 20ml of catalyst per 1L of topcoat I used 2ml leaving the topcoat semi-solid. Slightly tacky to the touch. What can I do?
A difficult one and you may get away with it if you can wait for the topcoat to cure......other than that I guess its a scrape away task and then refill with the correct mix.
John :)
If I use a scraper will I need to clean the remaining topcoat off with a solvent or just apply a new topcoat?
Personally I'd not use the solvent but rather scrape away what I could, and then reapply the new matting - stippling well so the resin oozes through well.
Of course, the topcoat may go off in its own time......I can't confirm that for sure.
John :)
Looked at it this morning an it seem to have gone a bit harder since yesterday. Maybe worth hanging on to see
