Hello
I need to replace all my interior doors. At present I have doors which look like they were all made on site to fit the frames. Not one of my door frames are the same size. To start off with im doing the Living room door first which currently it too high and not wide enough.
The question is, I need a door 762 x 1960mm but cant seem to find any 1960mm tall. They all seems to be 1981mm. I know you cut them back but is it possible to take this much off? 21mm?
I tried trimming the current door to fit properly but its such a bad fit I couldnt trim enough off without hitting metal pins in the wood holding the door together
