Nyone installed a Sanicompact?
26 Feb 2005
Gwynedd
Yeah, I know it'll cause troubles in the future, but the least i can do is ensure it's installed right in the first place.
To save space now, if you are experienced at these, make yourself known and I'll put my question - its a bit long-winded! Cheers
Where the instructions point to where the basin waste will attach, there is a domed topped-cylinder, 32mm ish in diameter. Am I right in thinking the dome needs to be sawn off, or have I been sent one WITHOUT the basin waste option? Thanks
yes the connection at the bottom of the toilet.
cut the top off leaving enough to fit the pipe and clip.
While we're here, there is what appears to be a blck rubber overflow pipe leading from high up on the pan. If this is what it is, where do they expect me to connect it to?!
