Oak Wardrobes
16 Jun 2010
Lancashire
We have had some MDF wardrobes with oak veneer on installed.
They look good and I don't want to 'darken' them.
I'm wondering what to vanish them with which will no change their colour at all.
I tried a 'clear' vanish (on a spare piece) and it went quite a bit darker.
What would anyone recommend.
Thanks.
Varnish will show the true colour of the wood. If its going to go darker then you cant stop it. I would use a water based varnish like Dulux diamond glaze, very hard wearing.
heeelllooo and welcome lkalka :D :D :D
the only way to not darken is not to treat :cry: :cry:
when you coat you effect the way the light reflect and is absorbed by the wood try wetting you will get a much darker shade very simmilar to oiling varnishing ect
of couse the wood will naturaly darken /lighten when exposed to oxygen and light the type off wood determins actual effect
Screwfix (amongst others no doubt) sell a product called patina
I used this to great effect on oak (both solid and veneered)
you apply it with a cloth (wear gloves it takes the skin off the ends of your fingers)
one coat hardly changes the colour
second coat slightly darkens it (only v slight)
It dries giving a very tough finish and one tin goes a hell of a long way
Thanks for all you replies.
I may try the patina on a spare piece and if it looks ok then use that.
Mick.
Sikkens TSI Interior (colourless) is also worth considering. I've just used this on some oak Veneered doors as the finish looks brill.
Thing is like I and Big-all said, anything liquid that you put onto timber will darken it. As said rub a wet cloth across the timber and thats how a colourless liquid will change the finish of the wood.
