Hi all,
I'm wanting to repurpose an old dishwasher and turn it into a parts washer for my garage. My aim is to run the dishwasher from a recirculating water based solvent solution. This would require a header tank, a filtration system and some sort of pump.
The dishwasher intakes water at a minimum of 10 litres/min, finding a pump to supply at this rate is quite easy, but I'm wondering what pump you would recommend? Would I need a pump like a shower pump, with automatic cut in & out? Or could I use a constant running pump but plumb it to recirculate?
Thanks in advance.
Thanks in advance.
