Hi All
Hope you might help at all. In short we have no heating upstairs, all rads are stone cold from the feed and return pipes of each rad up to the top of the rads - not even tepid.
We have two heating circuits. one which is underfloor heating to the entire downstairs of the house. The other circuit is for upstairs, however there are two rads downstairs linked to the upstairs circuit. This has all be totally fine in the 7 years all the work was done. The odd thing is the two rads downstairs linked to the upstairs circuit are both nice and hot as well as the underfloor heating circuit.
Ive checked the following:
Many thanks
Steve
- CH pump. Its only 6months old (Digital Wilo) and operates fine. It has a air purge function which ive run a couple of times
- Bled all rads - all full, no air
- checked all TRVs and pins are free
- All motorised valves actuating when the Nest thermostats call for heat
- checked tank in the loft and the float is free and tank is full
- Boiler firing up and heating the two rads and underfloor circuit
- Hot water all fine.
Many thanks
Steve
