Hi
Installing a new toilet to existing pipe work. The new bog is about 20mm lower than the soil pipe. No idea why, the old one wasn't that old, and was not sitting on anything.
I have bought a 20mm offset connector which centres it perfectly. However, it leaks slightly. No major worries, as I guess a flange is caught somewhere which will be obvious on removal, but it got me thinking...
The toilet is still lower than the pipe, so there is a very slight 'uphill' gradient in the pipe work, so presumably always a little reservoir of water against the connection.
Are offset connectors designed to be used in this way (ie to raise the connection)? Great idea, but I guess you can cheat gravity...
If this fails, I'll mount the toilet on a small plinth.
