Hello,
I have a mobile home, which has an oil boiler.
I am having trouble keeping the system working, it cuts out at 23deg.
I am planning to move the boiler outside and have already repositioned the fuel tank, but want to get the thing running properly before i move the boiler.
The system has a hot water tank. and the control box is bolted tio the underside, it has 2 switches and a 2 dig display.
Turn on the main power and the control box clicks a bit, and then the system fires, (sometimes i have to give the control box a knock to get the boiler to fire)
it gets to 23 deg and then cuts the boiler but the pump still goes on untill the control box shows error 6L.
I have replaced the imersion element on the tank with a new one.
The system does hot water and heating, i have also checked the thermo and digital control setting in the kitchen panel.
I think the control box might need replacing?
