I have been setting up my boiler (ancient Danesmoor 20/25) using a flue gas analyser ( I should say straight away I am an old fashioned mechanical technician and not an oil engineer).
Tha main reason I hired the analyser was to check a relations condensing oil boiler (Grandee) which was sooting up regularly-they had been told that the best bet was to have it cleaned/serviced every 6 months,everything in my engineering background told me this wasn't right,and my own edlerly boiler would go for long periods if no components failed with almost no sooting.
The Grandee guy told me to fit a modified flue kit,removing the original diverter.
Having used the analyser,I wondered if there is a relationship between Co and sooting,or rather should the Co level be targeted-the Grandee meets all the burner flue gas specs,but I can't find a Co level anywhere-I'm getting 30 ppm on the Grandee,my own ancient Danesmoor is 19.
I know this an area where experience is so usefull,I worked for several years with a small plumbing company who undertook both gas and oil installations,but they only needed one boiler engineer.
