We had an oil-fired boiler installed two years ago. It worked fine for 2 winters. Last week we tried to fire it up for the first time since February and failed. We got the local plumber (Greek) and his apprentice round. The apprentice did a "service", which I didn't watch but he started by cleaning out the soot. I don't know if he cleaned out the oil filter. Eventually they (with my help) traced the fault to the Siemens thermostat, one of whose "finger" contacts was not making connection and showed signs of arcing. I swapped over a pair of (unused) good terminals and all was well. The boiler fired up and the plumbers left.
5 minutes later, as I was bleeding the radiators, the boiler stopped working and I can't restart it.
I've set the thermostat to permanently "on" and the contacts are definitely closed because the red circular lamp on the boiler (see photo) is brightly lit.
I hold the start button in for 5 seconds then release.
The blower runs loudly for 5 seconds, then I hear a click and a humming sound like an AC-powered solenoid for just over a second, then everything goes quiet. I can repeat this ad infinitum.
I'm a 60 year old electronics engineer with electrical and mechanical knowledge so I can do pretty much anything, although I may not understand specific plumbing terminology.
I have access to a reasonably comprehensive tool kit, multimeter, current probe, soldering iron and other stuff.
There's over 700 litres of diesel oil in the tank outside the boiler shed.
The two knobs are set the the correct temperatures that they've always been set to.
Can anybody tell me what I should be testing/ looking for, please?
I can provide additional information as required. Many thanks in advance.
(I'm in Greece right now, by the way.)
