I'm replacing my oil line to the boiler. I am aware I'll need some isolating valves, a fire valve and filters. I have decided on the following:
KBB fire valve - valve outside but sensor in boiler housing inside house
Atkinson Tankmaster oil gauge - on all-in-one isolator/ filter/ gauge
I will also buy (and learn how to use) a pipe flaring tool, if required.
My question is: if I'm not supposed to use compression fittings on the oil line, what fittings are on the equipment mentioned above, and if these are compression fittings, why can these be used?
Ta
Ta
