I hope someone here can help me with troubleshooting my heating system.
I usually run the room thermo on 21.5 and hot water around 55c - continous, but the other day it suddenly started to get hotter and hotter.
I first set room stat to 17c and hot water to 40c but it still got warmer.
I then switched the programme to off but it still got warmer.
I've switched the system of at the mains when it got to 29c!
The controller is a honeywell smartfit YPlan. My first thought from reading through the forums is that it was a problem with the actuator. I have tried to remove it from the A/B valve and it seems to switch fine back and forth either manually or automatically when you power on the system.
Boiler is a Mexico Super 480FF.
There are no fault codes on the room unit and I have gone into installer setup mode to check through all the parameters which are set to default values.
Could it be a problem with the base/room unit, or does it still sounds like actuator (ML7300A)? What should my next step be in diagnosing the problem.
Thanks for any help!
