Hello all,
I am new to this forum so take it easy, I have done a search within and found some very helpful advice.
I am aware this topic has been covered before, but I have not found my answer.
"so what am I babbeling on about you may ask?"
Power to the garage, I need electricty in the garage, I live in a ground floor massonete with a garage about 20ft from the kitchen door leading onto the garden.
Before you ask I am a novice with electrics, but not stupid.
I would like to ONLY dig the trench and run the cable from the main fuse box to the garage.
My question is how do you run 90 degree bends in the amoured cable, (what I mean from the under ground trench, to up the wall at the back door then into and through the wall) or should I say what do I need to buy, I guess it must be some form of juction box.
Any advice would be great and as stated I am a novive, I am just trying to save on cost when I get an professional electrian in to check and wire up.
I was thinking of a trip next to the fuse box in the house, another one in the garage, then a 3 pin for power and then some sort of tube light.
Once done I can start my late winter rebuild project.
Many thanks in advance have a good one.
regards
TopiToo
regards
TopiToo
