When replacing my soil stack I noticed the 90' bend was broken so I dug it out and have since sourced a new one.
The old joint was sealed with rope and the filled with compound at a 45' angle, the same as illustrated in this picture.
http://www.pavingexpert.com/images/drainage/drn026.gif
Should I try and reseal this is the same way, if so should I use the rope or just fill it all with compound.
Or, should I just cut the female joint off and use a rubber slip connector with jubilee clips?
For some reason Im a little reluctant to cut the old joint off.
