2 questions....
1)
Tricky one here, house is about 300 years old, 2 of the down stairs rooms and landing have concrete floors, one of the floors was covered with lyno, when pulling it up there was puddles underneath. However with a day in the air its now dry. I'm 99% sure this has/is pushing damp into the internal walls etc. Whats the best way to stop this? I now need to replace lower timbers etc also on some parts.
2) what was once the kitchen is suffering from the same, however on this the floor has a resin applied so the floor isn't damp at all, however due to exterior concrete render over the solid walls and the concrete floor pushing the moisture I have the same problem. I've started to remove the render inside and out, some of the stone was wet to touch but seems to be drying out very quickly. Whats the best thing to do with this floor?
I guess the floors were at one point just stone on earth, in the hallway its now just 3 inch of concrete with no DPM underneath(which would still push moisture anyway), the other room i'm not sure how thick the covering is or whats underneath.
Where do I go next
Thanks all in advance, I'm just off to unblock some drains!
1)
Where do I go next
