old light timer
Sorry about the pictures not right way round
If a mod could explain why that is happening?
OK, I've never seen one of these! I'd guess that behind the fixed plate is an escapement just like in a clock. The pendulum will be attached to this The solenoid goes full travel, but the numbered arm changes the distance that the long arm is moved. When switched 'on' the solenoid fires, moving the long arm against the spring and the long arm attachment makes a contact. The spring now pulls the long arm down at a speed controlled by the escapement and the pendulum. At the bottom of the stroke the contact is broken so turning off the light. It can only work one way up.
It doesn't look like you need a connection to terminal 1, just wire as per pic. Looks like 2 to live, switch neutral (urghh) to 3, switch output is 4.
There looks like some sort of internal bridging to terminal 1.
The switched neutral is very alien to me and is against all i have been told
This replacement timer it seems like the neutral is switched, its hard to tell
This is a site to another timer where the neutral is switched?
I thought that was not allowed, unless I have missed something
Half way down
http://www.relay100.com/upfile/2006619179815036.pdf
This is what I am trying to do
This is the diagram of my timer
It is controlled by a push switch
Could some one please tell me how this is all connected together.
View media item 53488
Live to terminal 2,
Neutral to lamps and push buttons.
Switched Live comes out on terminal 6
Terminal 3 is one end of the solenoid coil, the other end needs to be connected to Live.
If terminal 1 does go to the coil then there needs to be a connection of some sort between terminal 1 and terminal 2. This is probably a contact that opens once the solenoid has been pulled in. This would prevent the coil being permanently energised to prevent over heating if a push button was jammed in. Many solenoids do overheat if permanently energised.
View media item 53509
Thanks very much Bernard
Yes this was the original wiring, I was confused as a neutral does not appear to go to the solenoid.
there is also a perm live and a red conductor to 3.
I do not understand the neutrals to push buttons
I presumed you would have a live to the push switch, which when pressed would send a live back to the timer which pushes down the solenoid and makes a connection to switched live and you have light till the solenoid is pulled back up.
How do the switches work
the modern one switches the common between make and break, i just don't get the neutral situation
any guidance would be really appreciated.
In the diagram, what would go to where.
I have looked all over the internet for wiring diagrams for staircase lighting but can't find anything, it is most frustrating
The push buttons are switching a Neutral to a control input. ( one side of the solenoid coil ). The Live potential on the push button(s) comes via the coil of the soleniod. As far as I know switching neutral to a control circuit is allowed.
