Old Vulcan boiler pump sticking
19 Sep 2007
I have a very old Vulcan boiler and now the pump sticks more often resulting in a sharp hit on the side to get it going again. Because this is happening more often It has started to weep around the pipe join and rusting a bit.
I would appreciate it if anyone who knows about this kind of thing would view the links below to get an idea of what I am talking about and give me some advice. I want to avoid hitting the pump now because it won't help the leek. I did drain the radiators a couple of years ago to get rid of the brown sludge but it must have built up again hence the pump sticking.
I have been told that there is a government grant available to help with buying energy efficient boilers. This obviously isn't efficient but we are in no way able to afford a new system.
http://i135.photobucket.com/albums/q147/hubballi/Vulc2.jpg
http://i135.photobucket.com/albums/q147/hubballi/Vulc4.jpg
Is it something I can do myself or would I have to get a Corgi reg plumber ?
looking at the kitchen cupboard the boiler is fitted in there is very little clearance and no obvious ventilation. The pump is a simple job but I would make sure you have adequate ventilation and the boiler serviced! You may want to consider a good CO detector too. Warmfront/warmsure do give grants to those on benefits/low income/disabled towards new boilers I suggest you google it and look into it. That old Vulcan is potencially dangerous and definately very inefficent.
...but I would make sure you have adequate ventilation and the boiler serviced!...
And looking at the second picture, unless that bottom part of the cupboard is removable I would doubt that the burner assembly could be taken out for cleaning/inspection anyway. :roll:
There is a vent on the back of it that goes outside the house. It was checked by the guy who fitted the meter.
Do any plumbers on here know roughly how much a basic check or service would cost for this old thing. As there is corrosion around the base, is there a chance it could explode?
The pump if left for a while will work but if it started soon after the last time it was on it sticks. I don't want to hit it anymore because it might rupture the seal.
If so, I am in Cheshire if anyone who is corgi and reasonable would be willing to come out :lol:
As you were already told on the MSE forum the cupboard around the boiler needs to come out in order to service the boiler and I wouldn't expect good news!
Which is why Im a here too as well as the MSE forum because not everyone's professional opinion is the same. :roll:
