Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
can anyone help ?.central heating firing up then turning off after 20 seconds.have bled rads. and run water out of last radiator until runs warm.heat upstairs and plenty hot water ,but no heat down stairs .helppp Marydi.
A boiler today was doing the same thing. Pump knac'd and full of sludge. Yours may be similar.
Check for airlocks in the boiler or lack of water in it, too.
Is there a manual air vent near your cylinder?
If so have you bled it?
Use a big screwdriver as a listening stick. Can you hear the impeller spinning or is it just a buzz or is it silent?
Is there mains voltage at the pump?
Chuck a towel underneath it to catch the dribble of water. Undo the big screw in the middle and stick a screwdriver in there. Does the shaft rotate?
hello Slugbabydotcom.Thanks for advice, boiler running o.k.today.I have not had to try anything else but will keep your advice to hand for next time ,cos i'm sure there will be one !ta. Marydi
