- Joined
- 13 Nov 2017
- Messages
- 99
- Reaction score
- 4
- Country
Hello
Before I start, I know next to nothing about plumbing - so any replies would need to be written in very simple terms...any jargon, technical terms, or abbreviations/acronyms are going to confuse me further!
Just moved into a new house, which has a Baxi 105e Combi Boiler. Seems to be working fine, apart from a minor problem.
When the heating comes on, they all heat up quickly and the heat is really pumping out of it - but then, after about 20 minutes one of them isn't hot anymore. It doesn't go cold, it's still warm to touch, but not warm enough to actually make any difference to the temperature of the room. Eventually it will heat up again, but then the temperature drops in a different room.
I've mentioned this to a few people who have all said it is an air lock and to bleed the radiators, but I have done this and no air came out of any of them - just water started coming out as soon as I turn the key. I've also seen on some forums that you shouldn't bleed radiators which have a combi-boiler?
If there is an airlock in the system somewhere, should I find it first time? Or shall I go round and do the bleeding a few times in case the airlock is in a pipe somewhere at the time that I'm trying to do it? Or should I not be bleeding them at all? And when the water comes out how do I top up the water in the system? Is that the same valve as increasing the pressure?
Also, there are only the temperature dials on the front of the boiler - I haven't got a Nest/Hive thermostat attached at the moment. The boiler is in the utility room on the side of my house, not actually in my house.
Any advice is much appreciated!
