    Dismiss Notice
One pipe system - bleeding radiators question
Discussion in 'Plumbing and Central Heating' started by Swell1, 22 Mar 2021.
  1. Swell1
    Swell1
    22 Mar 2021
    29
    Thanks Received:
    Country:
    Hello, we've moved in to a property with a one pipe heating system with a combi boiler. Most of the radiators are mildly warm - some are warm'ish at the top and cooler at the bottom. I've tried to bleed them but water just comes out and no air. Do I just keep letting out water until the radiators start to even up with the heat?
    It also doesn't have great hot water, could this be related to the problem above? (The water pressure is good)
    Many thanks
  2. Sponsored Links
  3. cross thread
    cross thread
    8 Sep 2005
    1,543
    Thanks Received:
    241
    worlds end
    Country:
    One pipe system are generally not as good as a two pipe , hot water should be ok have you got the hot water thermostat at the correct setting
  4. Swell1
    Swell1
    22 Mar 2021
    29
    Thanks Received:
    Country:
    Hello, thanks, yes I'm told they are not great and we plan to change it to a 2 pipe system soon'ish. I'm not sure where the hot water thermostat is located? (Boiler is a Worcester Greenstar 28i Junior)
    Thanks.
  5. Harry Bloomfield
    Harry Bloomfield
    30 Dec 2018
    5,758
    Thanks Received:
    826
    Country:
    No, I think what was meant was the boiler's heating water temperature setting, if it is independent of the hot water setting - try turning it up.
    • Thanks Thanks x 1
  6. Swell1
    Swell1
    22 Mar 2021
    29
    Thanks Received:
    Country:
    Hello, it seems that the boiler water temp is set and cannot be adjusted according to the manual? Thanks
    • Thanks Thanks x 1
  7. Sponsored Links
  8. Nige F
    Nige F
    28 Jun 2005
    21,092
    Thanks Received:
    1,722
    Country:
    According to the online users manual - it's the hot water to the taps that can't be adjusted . The boiler temp. ( as Harry said) is adjustable , 6 settings with a knob to turn. On the front panel
  9. Swell1
    Swell1
    22 Mar 2021
    29
    Thanks Received:
    Country:
    Ahhh apologies I may have misread that. Yes I can see that so I'll turn it up. Hopefully that makes the radiators and water hotter.
    Thank you all.
    • Like Like x 2
  10. muggles
    muggles
    28 Oct 2005
    12,860
    Thanks Received:
    2,880
    Daventry
    Country:
    Do you have TRVs fitted? There are special TRVs available for one pipe systems which allow a much greater flow through. Standard TRVs are often too restrictive
    • Like Like x 2
  11. Swell1
    Swell1
    22 Mar 2021
    29
    Thanks Received:
    Country:
    Hello, thank you, some have them on, we now plan to remove the whole system and fit a standard system with new radiators as they are old and all the pipes are on show. Many thanks 1
    • Like Like x 1
  12. muggles
    muggles
    28 Oct 2005
    12,860
    Thanks Received:
    2,880
    Daventry
    Country:
    Take the opportunity to upgrade the radiators while you're at it and get them properly sized for a condensing boiler.
Loading...
Share This Page
