Hope someone can help! All radiators in my flat work perfectly except for one in the living room. It's stone cold as are both pipes leading to each side of the radiator. This is what I've done troubleshooting wise so far.....
1. I've repressurised my combi boiler (showing just over 1.5 now)
2. Bled all radiators (no water comes out of the cold rad but all others seem fine)
3. Turned off all radiators except the faulty one
4. Checked both valves (TRV and the standard lockshield one) are fully open. The TRV PIN is fine, it presses down about 5mm or so and then springs back up so looks good. I've removed the white cap of the lockshielf valve to ensure this is fully open which it is
I'm at a loss as to what else to try?!
Read more: http://www.diynot.com/forums/plumbing/cold-radiator-cold-pipes.304625/#2228079#ixzz2C6vyxm3P
