One radiator not working
14 Jun 2007
West Midlands
I have a problem not so now but will in the winter, I recently installed new radiators up stairs as there were not any when I moved in, when I turned on the heating all of them worked but found a leak down stairs as I changed all the thermostats i then had to turn off the heating & water supply take the thermostate off the radiator and resealed it then turned on the water and heating now all of them work except one down stairs in the hall way what could be causing this? can anyone help
Did you turn the lockshield back on as well? if so probable air lock
:wink:
do a search for removing air
If it worked before then its an airlock,turn off all rads exept that rad and turn heating,the pump will push the air through that rad..
hope that helps
:lol: :lol:
has the one in the hall got a TRV? sometimes they jam.
Have you wound the valves at each end all the way closed then all the way open?
(note that if the valve jams, some plastic caps will appear to turn while the shaft does not, so you need a very small spanner on the flats)
