I have an irritating condition with my CH system in that no matter what I do this one radiator will not work, and when all the other six are hot it remains cold.
I have read loads of posts from a search and tried pretty well all the suggested cures with no success.
The boiler is a Worcester CDi30 which is working fine, and the problem radiator is downstairs below the master bedroom with it's feed and return in corner ducting which goes up to the bedroom and under the floorboards along the full room length towards the rear kitchen where the boiler is located.
Much to my wifes displeasure I have rolled back the carpet and lifted the floorboards and have identified the 15mm feed pipe which just like downstairs is cold, and half way along the room a T feeds the bedroom rad with microbore and at that junction the pipe is hot with the room rad also working normally.
As I run my hand along the 15mm feed pipe in the direction of the downstairs drop down it gradually becomes cooler until finaly cold, and that change is happening in about 2 mtrs of pipe.
I can only think it's a very stuborn air lock or a severe blockage, and I've bled about 4 pints out of the rad top to no avail.
Any ideas please.
Regards Ravel
Any ideas please.
Regards Ravel
