Put it all back and call an electrician. If you can't even be bothered to buy cable, you should not be doing anything with a light switch except flicking it on and off and giggling at the shiny lights.carrieo said:My question is, what kind/size of wire do I use to connect the switch panel to the earth wire that's already inside the mounting box? I have some 30amp and 5amp fuse wire, would that do?
