I’m hoping that someone on here can help. My partner and I have an open vented CH system, the pipe work is microbore. I’ve drained and refilled the system several times and circulated Fernox but the problem is this...when the heating is on, only some of the radiators are warm at the top and cold in the middle whilst others feel like only a small amount of hot water is getting to them. I replaced an old radiator with a new one and even the new one is only warm at the top. When you turn all the radiators off and I leave the one on the landing (closest to the airing cupboard) its scalding hot all over, the problem starts when I turn on the other radiators. There are 8 radiators in total, though the one in the kitchen is never used. The radiators furthest from the airing cupboard downstairs are the worst for not getting very warm but the ones upstairs in the bedrooms aren’t as bad.
Pump is a grundfos 15-50 and it’s set on speed 2.
I’m considering a power flush for the system but I’m not sure if this will help or make things worse-please can someone advise?
I’ve installed a TF1 omega filter, but I think this may be on the flow rather than return side. Could this be the problem??
There was a gas fired back boiler as the heat source but this was ripped out and has been replaced by a heat exchanger fed from a Solar Bayer stratification system. (The water temperature of the water isn’t the issue, it is scalding).
All of the radiators have lock shield valves on both sides and I know which is glue/return. Do you balance radiators on microbore? If so, how as I’ve not had any experience with microbore systems.
Any help would be gratefully appreciated
