Opinions on this rendering work please
27 Jun 2006
I have had some rendering work done and would welcome your comments. I was unhappy with the area surrounding the window frames but have been told it has been built up as much as possible and will need to be filled with silicon or covered with plastic. Also, I expected the side of the building to be done but was told 1 it was next door and 2 the scaffold didn't go round so not done!
GALLERY]
GALLERY]
GALLERY]
GALLERY]
Hope the pics have worked
The finish to the reveals is very poor, the side bit looks to be part of your building but there is no scaffold there to do it from - and jesus, did they ever leave your windows in a mess!!
I can wash the windows but I wasn't happy to see expanded foam exposed round the window edges. It wasn't visible before so why now? Is there a limit to render depth? Should they have at least filled in the chips to the pebbledashing on the corners? Or are my expectations unrealistic?
Render of that type rarely lasts. You'll be doing it again in a few years.
How the blazes can you tell what sort of render it is from a photo? I didn't even realise render came in different flavours.
The same way a doctor knows your illness or a mechanic your faulty car.
It's a bodge. Simple as that.
Did your quote include the side of the house?
You should have simply patched the original up using a tower scaffold.
£450 including scaffold hire.
Did they specify stainless steel beading? If they've used galvanised you'll soon start to get it rusting out.
What did you pay for half a house and a poor finish?
