The control panel on my alarm does not beep whilst using keypad, is this a fault or can it be rectified somehow, any advice gratefully accepted, thanks in advance
You will normally get an entry and exit tone/sound when setting and unsetting.
Does the red day light go out after 30 seconds?
If you enter code and get some to walk in front of a sensor that should light up red on the zone number which you have walked in front of.
That would suggest code is correct.
Are you sure you have correct code ?
Could be faulty speaker in control panel ?
Lights illuminate as expected, ie open door on zone 2-red light etc. Definitely the correct code, im the only one who knows how to use alarm in house. Ill investigate further in next day or so, thanks for help
