Optima XM Reset
24 Mar 2011
Just moved house and already has XM fitted
No pin number available
so following instructions I have carried out full reset
connecting PA to Set
now keypad doesnt work
any suggestions ??
Oh dear, my suggestion would be to bin it, but thats just me :)
You have removed the link haven't you??
hi have you closed all the tampers ? as the keypad will seem dead untill tampers are clear then press reset !
yes link removed and tampers all clear
thanks for help
Okay so the systems "locked out" due to a fault somewhere. Was the keypad working before you opened the panel??.
If all was ok befor you opened the lid there will only be 1 tamper which is the lid, check the spring and try again.
Could be the battery, as this acts as a big smoothing capacitor on these panels and a duff one can make them lock out.
Yes it was working before
Thanks for battery suggestion as it was only 8v when I disconnected it
I'll try that tomorrow
