Just a couple questions on the roll call of decoration order in my bathroom!
1. Steel bath is in position (with wall mounted taps)
I've built half a frame with 2x2 batten's on the supporting walls.
As the flooring hasn't been done yet, I've left the exposed sides as the new flooring will encompass a 5mm plyboard covering the entire room as the floorboards are all over the place and then the vinyl flooring is going on top of that.
Option A - Should I finish the frame so the ply flooring will butt up to the frame or is it better to have that running under the bath for a few cm more?
Option B - Should I be running mastic round the half full bath and then tiling with half a frame done, then worrying about the rest of frame after the tiling has been completed?
(I take it that the flooring should be the second to last thing to be done (with the bath panels being the final piece in the jigsaw)).
T.I.A!
T.I.A!
