OSB3 board options and direction for flat garage roof
27 Jul 2006
I'm about to board my garage roof
Length is 7.3m x ~2.4m and the garage is link detached joining me and my neighbor
Can anyone confirm the following for me please :
  1. are the tongue and groove or flat edge panels best ?
  2. screw down or nail down ?
  3. should i lay the OSB3 boards length ways down the length of the roof and then stagger, or across the width ?
  4. if using the t&g boards, must they join on a joist ?
  5. i assume flat edge boards MUST join on a joist for strength ?
  6. as its a link detached roof between 2 walls, how tight should the boards be to the brickwork, considering there will need to be an arris rail around the edge (tight or 5mm all around ?
Thanks in advance (y) and sorry if any of these are dumb questions :confused:
Sorry for the bump
Would anyone be able to advise please as I'm hoping to purchase and board this week ? (Between rain showers that is)
What are you finishing the roof off with (weatherproofing) and what are the joist gaps, centre to centre.
Either ivor for T&G or not.
The boards should go longest length ways across the joists and stagger the joints 1/2 bond like brickwork.
Yes the boards should butt over a joist, but you don't need noggins under joints between joists if the joist space is 450mm or less, or if T&G.
Use screws (best) or ring shank nails
Leave a 5-10mm gap off any wall to avoid any damp transfer
Thanks Woody
The new joists that i have installed to extend my flat roof forward are at 400mm centres so they are likely good and i can butt them over a joist, but i can't vouch for the old joists and where the joints will land
As i see it, this is more of an issue where the boards are flat edges, but where it is T&G and they join between joists, how much of an issue do you think it will be, or just beef up underneath with a noggin to help ?
Thanks again for your valuable input as always
So i've just been on to B&Q's site and can see that they have 4 x 18mm options :
https://www.diy.com/departments/bui...erials/sheet-materials/osb/18/_/N-8tuZ1z0niir
Description :
Smooth OSB3 board (2440 x 1220)
Smooth OSB3 board (1690 x 645) - TGV4
Smooth OSB3 board (1220 x 610) - "Softwood"
Smooth OSB3 board (810 x 410) - "Softwood"
I'm thinking of the TGV but am puzzled by the "softwood" options
Can anyone confirm please and whether they are all suitable for construction/a garage roof also ?
Are they all equal, except for size (obviously) and whether flat or T&G ?
Looks like B&Q crap descriptions.
But those are some random sizes for boards. You really need 2440x1220 or x610 for roofing
