Hi all,
Occasionally, there is no water from the Outdoor tap.
Replaced tap. No difference. Took tap off. Check valves work, washer in place, unscrewed head from the body and tap all clear. Tap mechanics seem to work when off the wall. Sometimes no flow from exposed pipe with tap off the wall.
Peglar double check isolator valve indoors turns ok. Took plastic handle off and turned the spindle with grips on and off. Still the sporadic loss of water occurs.
Had kitchen replaced 2 years ago, but problem only started 1 year ago.
Is it the isolator valve that is likely to be faulty do you think? To replace valve would mean cutting the back of sink cupboard out and my back is painful so would rather not.
Any other thoughts before I call my trusted plumber in to look?
Thanks.
Thanks.
